Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
Analog stick replacement CECHZC2E
I disassembled my PS3 Dualshock 3 controller, because the left analog stick has broken, and didn’t move back to the middle position. (Looks like the spring not functioning)
I desoldered the broken analog, and ordered one with the same pin layout (3pin version).
When the new part arrived, I had realized, while the number of the pins are the same, their position are different, so I cannot solder it to the PCB.
I searched on the web, but I didn’t find that type of analog stick, what I exactly need. (Just the 3 and 4 pin version, which are not what I need)
Do you have any idea or tip, from where can I order this kind of analog stick?
Score 1
1 Comment
I am facing same problem, still couldnt find similar looking analog stick. All looks smaller like djjano1 posted and if they dont look smaller the micro switch looks like 6mm version instead 4.3mm like on this analog. I have same CECHZC2E B1 dualshock3.
by
Add a comment
Most Helpful Answer
djjano1 there are 3 revisions of the Dualshock 3 CECHZC2E, CECHZC2E A1 and CECHZC2E B1. Your analog stick looks actually more like a PS4 replacement
Check on places like this for a better replacement
Score 3
Add a comment
Seems you have a new version of the controller, made for release with the PS3 Slim. Try looking for those parts. I couldn’t find anything quickly, but you can always try it yourself.
Score 1
Add a comment
Same problem Here.. no fix yet…
Add a comment
Apparently this version is really successful fake controller, hence the differences. I used Xbox 360/PS2 analog and replaced the push button of correct size (way smaller). Had to create holes in plastic for button legs but it works. Cost was under 2$, button were actually more expensive (1$) as I had to order at least 10.
My original idea was to use inside of new PS2 analog and replace the original one, but dont remember why it was not feasible.
Add a comment
I'f this model was fake?? Why did I get it in the box with the ps3 phat and the ps3 super slim sealed from the sony factory…
2 Comments:
SCP toolkit refers to it as fake, on motherboard sticker is not Sony but something else (forgot what exactly and too lazy to open the controller). I found it in past on some site in search of these weird analogs that its supposed to be really well done fake. That would explain why there isnt single analog for this DS3. Believe me or not, up to you. Its possible to fix it and it works as new, thats what matters to me.
If you post PCB from both sides, I might be able to find the site which claims that its fake.
Edit:
Found it is Asuka board
https://www.psdevwiki.com/ps3/DualShock_...
by
Add a comment
Add your answer
djjano1 will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 43
Past 30 Days: 166
All Time: 6,352
