A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
How to fix Eject sensor?
I recently purchased a used ps4 that has an issue with the eject sensor/button. The system reads and ejects discs just fine as long as I do it through the menu. So my issue is just the button or sensor. The power button and sensor work perfectly fine. Does it need a new button or could something be disconnected? Any help would be great!
Add a comment
1 Answer
Chosen Solution
You most likely have a model where the button is touch sensitive. In this case it’s usually either the metal spring that connects the eject button to the eject daughterboard is broken or bent. If it’s bent the wrong way you can bend it back so that it touches the eject board.
If it’s broken though you’ll need to replace the bottom cover.
Score 3
4 Comments:
That did the trick. Thanks a ton!
by
Thank you very much. Worked 100%.
by
Hello, i have tried this however i cant tell if the bit of metal is touching? Is there a trick or special shape the metal should be?
by
B Wallace I'm wondering the same thing can someone help , I've bent it right down , I'm thinking maybe it's the ribbon connection or something .
by
Add a comment
Add your answer
Christian S. will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 57
All Time: 2,762
