Up to 20% off select tools
Gateway laptop with 4 GB RAM and 500 GB HDD. Model number: NE56R49u.
I cannot type numbers
Hello i tried typing numbers, yet its not working,, rather only symbols are working.
I used the set of numbers at the right too yet they didn't work.
Add a comment
1 Answer
Chosen Solution
Hi @odimexy ,
Are all the letters OK or are they showing in upper case (capital letters) only?
If they are in upper case (capitals) only check if there is a Shift key stuck in the operated position as this will affect the numbers above the letters on the keyboard as well.
Have you checked that the Number Lock light is operated on the keyboard?
If not press and release the Number Lock key (the number lock light should come on) and then try the numbers on the keypad.
has any liquid been spilled onto the keyboard at all?
Score 2
Add a comment
Add your answer
Odidi Junior will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 26
All Time: 964
