Huawei's 2017 flagship smartphone. Released in March 2017. Features a unibody case and dual rear-camera setup developed in partnership with Leica. Comes in 32/64 GB storage options and six different finishes. Model numbers VTR-L09, VTR-L29, VTR-AL00, VTR-TL00.
Huawei P10 Antenna cable broken
So i was replacing the screen on my huawei p10 when i accidentally broke of the antenna connector on the board. i put the phone back together with one side on the antenna unconnected, thinking that the phone would work but i wont be able to make any calls. when i turned the phone one everything seems to be working fine. i am able to make calls and use wifi etc. My question is so i need the antenna, its currently not connected in my phone but everything seems to work fine
Add a comment
the network signal will be very low ( out of service ) cannot make call .
You can jumper the antenna very easy.
1 Comment:
is their a guide somewhere on the net?
by
Add a comment
I had the same issue. Broken off the connector when replacing the battery.
I've broken the connector from the main board, that's where the camera is located.
Connected the bottom side of the antenna. Strange thing is that everything works perfect. But I dont know if I have a lower signal.
Add a comment
Same thing here. Did you encounter any problem?
Add a comment
Add your answer
tony will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 23
All Time: 1,092
