Repair guides and support for the seventh generation of Ford F-Series trucks. Models include the F100 (discontinued in 1983), F150, F250, F350, and others.
Front signal light replacement wiring problem
I have a 1985 ford f250 and i had a bad turn signal socket so i ordered a new one amd when i got it the colors on the wires domt match up i have a brown black and blue on the replacement socket and a brown black and green on the truck my problem is I'm not sure what wires go to were if they aimt color coated please help
Add a comment
1 Answer
Most Helpful Answer
@jayrodisking08
the original would be
White to indicator switch
Black to ground
Brown to the headlight switch
Since we cannot see the wiring on your replacement, you could try to connect the blue to the green, since it does have a black and brown in common. Or you can post some good images of the new lights with your question and we could possibly help you to determine the hookup for the replacement
Score 2
Add a comment
Add your answer
Jordan McGuire will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 941
