Guides and support for various television (TV) brands and styles.
How to stop interference affecting tv
I have an ultrasonic aroma diffuser & when it cycles on it interferes with the TV.
How can I fix the problem?
Add a comment
1 Answer
Most Helpful Answer
Check your building wiring, often times poor grounding can allow EMI not to be dampened properly. Also check your breaker panels ground connection and the grounding rod or water pipe (metal) for good connections.
You might want to get a good surge suppressor for your TV that might help too.
Score 2
Add a comment
Add your answer
Philip Rogers will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 10
All Time: 905
