Support for musical holiday decorations by Mr. Christmas Inc.
My 6v adapter has interchangeable tips.
What is the correct tip polarity for the music box?
2 Comments
Thank you for your reply no label I’m familiar with what do you describe I’ll try the positive center hope it doesn’t blow up
by
Center +. Works fine! Thanks again.
by
Add a comment
1 Answer
Most Helpful Answer
Usually, the center is + There may be a label on it that shows a dot, mostly encircled with a line coming from the dot in the center. This line would be labeled with a + if my assumption is correct.
Score 1
Add a comment
Add your answer
Scott will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 220
