Repair information and support for GE Profile Refrigerators.
The water filter is leaking
The GE refrigerator is 2 years old. I’m in this house for about 1 year now and I replaced the filter once already. After 6 months, the water filter light came on again, and so I bought from GEappliances online a set of three new water filters MWF exactly the same as the one being replaced. The instructions says something about align the arrows and turn to the right until it stops. The arrow in the filter doesn’t have another mark to align to, but I managed to fit it in and twist to the right until it sops. However, it immediately started to leak. I took it out and try again, still leaking. Try for a third time, completely out and then in again twist it until it seemed it fits and turning more until it click and then it stops….still leaking. What’s the problem? I bought it as a genuine part from GE directly.
Add a comment
Chosen Solution
I’d replace the water filter head like this":
https://www.youtube.com/watch?v=AvHpBn9p...
Score 2
Add a comment
Look at O ring and inspect it for wear/tear and b sure to note that it properly sits between filter and housing. If problem still persist be sure to contact manufactur for potential recall on manifold.
Score 1
Add a comment
My GE inline water filter developed two pinhole leaks along one of the seams after two years of use. Woke up to the sound of floor tiles popping apart from their adehsive.
Add a comment
First, ensure the filter is genuine and not defective. Even genuine parts can sometimes have faults. If the filter is fine, the problem could be with the refrigerator's filter housing. It's possible that the seals or connections in the housing are worn or damaged, which can cause leaks when a new filter is installed.
I recommend checking the housing for any visible damage. If everything looks intact, you might want to contact GE customer support for further assistance, as they can provide more specific guidance for their models.
Add a comment
Add your answer
Cesar will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 130
All Time: 24,407
