No display on laptop
There is no display occurring on my lapty screen
beep sound are as follows
oneshort beep pause three short beep pause four short beep pause three beep
That beep code symbolizes memory failure, and or video failure.
Replacing the RAM should fix your issue.
You have 2GB of RAM preinstalled unless you replaced it.
https://www.amazon.com/dp/B00C538B56
In that link you can buy a 4GB kit, of the RAM that your laptop supports and fits. It is actually more RAM than you have now.
2GB x2 sticks. Try doing so. Pretty cheap as its old ram models. Only 17$
Could be cheaper on EBAY as well. Just makes sure it is that. (The link I provided)
PS. This should fix and boost your Laptop.
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 25
All Time: 533
you may have errors with two things basically Dual In-line Memory Module
and system board check them if any one will found faulty replace the part
by Amily Grey
@nmitt start by connecting an external monitor and see if it displays anything.
by oldturkey03
Like when I plug my laptop into the charger, it doesn't work and the current is coming to the laptop but it doesn't work.
by Raima rimi
