Up to 20% off select tools
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Problem with graphic card
My Mac seems have problem with graphic card (AMD Radeon R9 M370X) or something relate to graphic card
  • When plug in with external monitor, it use discrete graphic card, then everthing works well, except fan noise and heating
  • When unplug external monitor:
    1. if it use intergrated card, everything works well
    2. if it switches to discrete graphic card, the screen will blink, after a few minutes, it will display WHITE screen, and then it stucks. I can’t do anything , I must hard reset it
Thank for your advice !
Score 5
5 Comments
Lets correct a few points here your system came in two versions:
- MacBook Pro 15" Mid-2015 (Intergraded Graphics)
- MacBook Pro 15" Mid-2015 (Dual Graphics)
Basically the Dual Graphics models have in addition to the Intel Iris Pro 5200 intergraded graphics within the CPU chip have the Radeon R9 M370X GPU chip (not a card)
by Share
Hello, it is the MacBookPro11,5(Dedicated Graphics)
by Share
No worries, I knew that. Just wanted to make sure we where on the same page on what the differences are.
by Share
Hello did you ever find a fix to this problem? I have the exact same issues with my mid-2015 as well. I tried all of the fixes and still nothing. Fans will get noisy, mac will overheat and screen will go white.
by Share
no, maybe problem with logic board (or GPU), I tried replacing heat sink, but the issue still persists. replace logic board is too expensive, so I have to live with this issue (and use gfxCardStatus)
by Share
Add a comment
Chosen Solution
The video signal from the CPU has two different GPU logic paths going to the IG or via the DG, then the signal has three different paths by default the internal display via the internal DisplayPort (iDP) connection, then you have either the HDMI port or lastly the Thunderbolt ports treating the connection as a DisplayPort connection.
Depending on what you’ve set within the Energy Saver control panel if you’ve checked off the Automatic graphics switching. This sets the IG as the preferred graphics services unless the application tells it otherwise. Some actions within the startup settings will also force the IG as the preferred graphics services. Otherwise the DG will be used if available (the IG only models don’t offer this setting).
OK, now that we have a handle on how this all works we can try to figure out whats happening with your system.
Which are you using for your external display? The HDMI connection or the Thunderbolt connection?
Score 1
1 Comment:
For external LCD monitor, I use Mini DisplayPort cable to connect to Thunderbolt port. this works fine.
I only have problem when I don't use the external monitor, and with Dedicated Graphics (I installed gfxCardStatus to manage this, so I know when it use IG or DG). I tried turned off automatic graphic switching to only use DG, but it didn't help, I still got same issue.
by Share
Add a comment
If you don’t want any problems when you use dedicated graphics card (AMD), you MUST use only the default display settings for your retina display (i.e. 1440x900, it may also be designated as 2880x1800 in your computer since it’s quadrupled by using factor 2x2 for each figure, due to “retina” specification).
You can use “more space” or “larger text” options in Mac’s own display settings only when you switch off the dedicated graphics card.
Hope this helps.
Update (12/02/2018)
I can add one more additional thing to resolve the problem: You can disable switching (between dedicated graphic to integrated graphic) in the energy saver preferences, and this issue may be totally gone. The battery life may get shorter of course, since you are no longer saving energy (using dedicated graphics all the time).
By the way how do you know (how do you make sure) that it uses integrated graphic all the time ? I mean did you find a way to switch off the dedicated graphics card (such as https://gfx.io) ? I’m asking this because you say there is no problem when it uses only integrated graphics, however this is not normally possible by original native apple software. Either you have dedicated graphics all the time if you disable energy saving feature, or you have intermittent switching between dedicated graphic and integrated graphic during use. My guess is, the time periods you don’t have any problem are when you are on dedicated graphics all the time.
1 Comment:
Turning off the graphic switching worked for me, no more problem. Except that about 3-4 months later I got the white screen of death. I don’t know if turning off the graphic switching contributed to the failure but you should be aware of the possibility. It did work while it worked
by Share
Add a comment
Add your answer
Satashi Zero will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 38
All Time: 18,344
