Released July 2010, identified as the 1199DX version of the HP Mini 210 series. Typically identified by it's Pink casing.
Why is my laptop not charging
HP mini 210-4150 NR charging
Add a comment
1 Answer
Possible causes:
* The battery is dead.
  • There is no voltage output from the charger for a number of reasons (e.g. cable, fuse, or electronic component failure).
  • Failure of connection inside your laptop, so charging voltage does not reach battery.
If you have a voltmeter check charger output. If there is no output check/repare or replace charger.
Add a comment
Add your answer
Johnson. K will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 480
