Up to 20% off select tools
Released in March 2017, the G6 is LG's flagship phone running Android 7.0. This device is available across all major wireless carriers. Physical repair of this device may eliminate water resistance and cause the device to be vulnerable to water damage.
Touch screen not working
I have a phone labeled “LG Fortune 2”, I chose “G6” because appearance-wise it was the closest, “Fortune 2” not being in the list of devices.
It got wet though not soaked - rained on , predictably would not boot. The moisture telltales all turned orange.
I dried it out and it booted fine, screen lights normally, but the touch screen will not work at all. The only way to get it to light is the home button.
What, if anything, can be done to correct this?
Thanks.
Score 1
1 Comment
Thanks. I will replace the digitizer. I see they can be had for about $10.
by Share
Add a comment
Chosen Solution
Sounds like you need a front digitizer replacement. If that isn’t the issue, it could potentially be a logic board short. Water damage is tricky to diagnose directly, but I would try a digitizer replacement first.
Add a comment
As Jonathan said, water damage is tricky to diagnose. There may be corrosion on the screen connector causing the touch not to work. Its also possible a component on the board is shorted out. You will have to replace the whole screen assembly (glass, digitizer, LCD) if you want a new touchscreen because it is bonded together. A new screen will do nothing though if the corrosion isnt cleaned off of the connector, or if the logic board is shorted. Its going to be about the same or cheaper to replace that phone than fix the screen.
Add a comment
Add your answer
Andrew will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 2,178
