Guides and repair information for Insignia speakers.
Broken speaker plastic connection wire clips - +
I have 2 never used 4 inch three-way surround speakers. The wire connection spring tab in the back is broken. The spring loaded plastic connection tab on the back of the speaker broke off. This is where you plug-in the positive and negative wire. The negative tab is broken on each speaker.
I need 2 wire connection units?
Add a comment
1 Answer
Hi @jeffgray ,
Here’s a link to suppliers of the type of terminal connector that I think that you’re asking about.
Hopefully, by scrolling down the page, you’ll be able to find a suitable replacement part.
If not, post some pictures of what your connectors look like (add dimensions if possible and also the model number of the speakers) and perhaps someone will be able to find an appropriate replacement.
Here’s how to do this. Adding images to an existing question
Add a comment
Add your answer
Jeff Gray will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 42
All Time: 2,371
