does not connect wifi
where can i get a wifi card for this toshiba?
bonefont52, did you check to make sure that you wifi is turned on? Not knowing what OS you are using, I would check the BIOS and see if your wifi shows up and is recognized. Also check on here for more info. Try to reinstall the driver for your wifi, it is available here. If you do want a new card for whatever reason just check on Google there are plenty out there. Good Luck
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 14
All Time: 1,459
1 Comment
bonefont51, give us a bit more information. Why do you think you need a new wifi card? You checked all your settings? Did you check your BIOS, is your wifi recognized? What OS are you using? Anything happened to your computer? Did it stop working all of a sudden?
by oldturkey03
