This Audi A6 model received a facelift in 2001 for both sedan and Avant versions. The revised A6 sedan featured a new grille design and different headlights, while also being fitted with a wide range of petrol and diesel engine configurations. Most of these powerplants received a boost in power outputs.
What do you think it could be
my wife turned off the car. the antifreeze poured out of the bottom of the car
Add a comment
1 Answer
Chosen Solution
It sounds like you have a coolant leak somewhere. You’ll need to do some hunting around to find exactly where the leak is. If you’re in the U.S. Harbor Freight has a decent cooling system pressure tester that could help you pinpoint it quicker. If you can let me know exactly where the leak is I might be able to help guide you through the repair. Good luck.
Score 1
Add a comment
Add your answer
joelnolting3 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 62
All Time: 640
