Up to 20% off select tools
Released November 2013, identified by model number RVL-201(USA).
Disassembling Wii Mini Case Component
I want to remove the white rubber piece inside the case component that stops the discs, so I can get another piece for replacement. How can I take it out? Is it friction-fit or glued on? I bought this brand new a month ago, so I don't want to break anything. Help will be very appreciated!
Add a comment
1 Answer
Most Helpful Answer
it’s glued in sorry can’t take it out unless u use a hair dryer or a heat gun to melt the glue then replace it
Score 1
2 Comments:
Well, could I clean the front of it with something? I tried a couple of things, but nothing worked. It would have to either be cleaning it or taking it out and getting another one.
by Share
well you could try cleaning it with some windex
by Share
Add a comment
Add your answer
Isaiah Austin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 33
All Time: 651
