Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
Activate issue with no network works
Hello!
I have iphone 7 (A1660) with (NO service) problem , I tryed use ipcc files but carrier still Not Available, so I update to IOS 12 and now I stuck with activate issue(there is still no service,Even with use different sim cared), it saying Unable to Activate An update is required to activate your iphone. image below
I Noted when I eject the tray of sim cared, my phone do’s not say (No SIM card inserted ).
pleas help me!
Thank you before!!
Ibrahim
Score 15
1 Comment
I have same problem too
by
Add a comment
Most Helpful Answer
I solved that issues by changing BBPMU IC on iPhone 7 and restore via iTunes then my problem solved.This videos help me to find the solution.Hope this works.
Score 3
3 Comments:
where is the video? I really need your help sir, I got this problem for a month now
by
where is the video
by
@aresmuzamel
@MAKE
Click on solution to get video
by
Add a comment
This is a known issue with the iPhone 7 modem. Send in for repair with Apple: https://www.apple.com/support/iphone-7-n....
Score 2
1 Comment:
Apple says the fix it for free until you send them the device. I had the same issue and Apple says that my iphone needs a new screen due to a very little scratch and they are charging me 316+tax for that, so they fix the activation issue. Bottom line, they fix everything with the phone or nothing, you have to pay for the cosmetic issue so they fix the activation issue for "free". Scam
by
Add a comment
I had this issue with iPhone 7.
Did a chat with apple representative and they had me go to my iTunes and make sure I was updated first. Then turn phone off and connect to computer. Then open iTunes and let it install update.
It didn’t work.
She next had hold down the power and volume up button for about a minute or two until your phone shows that it is connected to iTunes, then the iTunes screen on my laptop was showing that it was extracting, then when it was done it started to update.
Phone turned off after installing and I was able to set my phone up.
Score 1
Add a comment
some people with this case get their phone back with changing baseband power ic on the machine board. May be y’all wanna try it too.
Add a comment
ich habe problem men iphon gleich ist was maen bite
Add a comment
if the model is of those : A1660, 1680 , A1779 then there is no issue coz apple said it, you can read this link :https://support.apple.com/iphone-7-no-se...
Add a comment
Fixed by adding another device to my account(iphone 6) then i removed my iphone 7 from list of trusted phones. That allowed me to activate.
1 Comment:
could you explain it a little bit more?
by
Add a comment
My iphone 7 unable to activate
Add a comment
Add your answer
Ibrahim Hassan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 21,985
