Up to 20% off select tools
Asus Q534U is part of ASUSTek Computer Inc. Q-series laptops. The laptop has a 360 degree folding hinge that allows the device to change between laptop and tablet by a simple fold.
How to replace lcd screen
I actually have the asus q524u which I believe is the Best Buy exclusive model? This is the only asus laptop I’ve found with the same hinge/case setup and is probably very similar.
I have some cracks on my lcd screen behind the digitizer. The digitizer glass is perfect and touch works perfect.
I have ordered a new screen that should be here in two days but I can’t seem to find any tutorials on how to disassemble the bezel and screen, I’d hate to have to guess and break clips off or worse.
If anybody has any experience please advise! Thanks!
Add a comment
1 Answer
Chosen Solution
https://www.youtube.com/watch?v=ynIQwPPD...
It Is not the same exact model in which I understand but it completely the same concept and should help you fine if not give you a great idea on what to do.
Score 1
2 Comments:
Thanks, I’ve watched that and many other similar as well. My concern is most of videos I watch there are hidden screws somewhere holding the bezel in place. I don’t see any so I may just pry mine
by Share
You will be ok man! Good luck
by Share
Add a comment
Add your answer
cbrackett90 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 17
All Time: 2,743
