Up to 20% off select tools
Clicky Mechanical Gaming Keyboard - Fully Programmable and 5 Macro Keys. First released in 2010.
Slow, delayed key response?
I’ve had my Blackwidow Chroma for a year or two, but only recently I noticed that, in games, the A key isn’t responding to presses in time. It can vary, from about a half-second delay on press, to a full 4 seconds, but it’s definitely there. Does anyone else have issues with this? Is this a common problem with other keyboards? How do I change out the switch if it’s compromised?
Score 1
2 Comments
I have the same problem but with my D key, has any fix been found for this problem
by Share
It also happens to me but in the R key and the V key, I have cleaned it up but it stills the same I really dont know why it may be the USB port
by Share
Add a comment
Most Helpful Answer
Can you pull keys off? Try pulling it off and see if typing with it off works well. You can also pull another key off from a key you don’t use and put it on the A key spot, doesn’t matter. Then try pressing on it and see if it works.
Score 1
Add a comment
Just turn off the LEDs.
Add a comment
It works if you turn of the LED’S as Filipi said. But the problem is the key that was lagging had been assigned as a macro key. Reset that to default and you are good to go. I dont know why this happend or how.
Add a comment
I have used static color and it seems to have fixed the problem. I’m not sure how this keyboard is built, but I suppose it’s the keyboard’s controller that has this issue…
Add a comment
recently my RAZER Macro keys of Blackwidow (M1~M5 keys) input speed slow down.
(kind window slow problem - they input funtion of M1~M5keys and there are deep delays - keep Ctrl hold kind...)
but i got a hint from these answers.
so i just turn off and back on about CHROMA color fucntion. it's fine now.
thank you guys.
Add a comment
Add your answer
Daniel Nicolson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 56
All Time: 12,668
