Up to 20% off select tools
The Tecno Y3s Android smartphone was released by Tecno in April 2015.
phone has a problem charging
i've assesed a clients phone and the charging jack is okay, but the phone still has a problem charging..where should i look?
Score 20
2 Comments
i've assesed a clients phone and the charging jack is not okay, but the phone still has a problem charging..where should i look?
by Share
Sir, my mobile battery is very weak, what should I do to get it fixed?
by Share
Add a comment
Most Helpful Answer
You should check the connections from the Socket Charging to the C - Power Bauur inside the device and your money using a device called Avoometer
Score 3
Add a comment
You can replace the charging socket witch is probably damaged unfortunately ifixit doesn’t have a guyed for it so look on YouTube for a guyed and i would say to go to eBay for the part
Score 3
Add a comment
To take a look on battery terminal if a well connected second to check life of battery
1 Comment:
Take a carefully look at the battery terminals if we'll connected, you can as well try boosting the battery if situation persist try replacing the battery.
More technical you can run a jumper from the positive terminal of the charging legs to the vbat.
by Share
Add a comment
Phone is not power on and showing logo
1 Comment:
@yashdahiya your phone is a Tecno Y3s? What have you checked? Anything happened to the phone? Did it get dropped or any water damage?
by Share
Add a comment
My phone charging socket is not working
Add a comment
No problem my phone is ok
Add a comment
Charging my phone slow way
Add a comment
Add your answer
Eric Matibila will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 37
All Time: 3,662
