The HTC U11 Life is an Android smartphone that includes models HTC U11 Life (32GB NA), HTC U11 Life (32 GB), and HTC U11 Life (64 GB). The HTC U11 Life was released in December 2017.
Battery replacement for HTC U11 Life
Hello,
I need a Battery replacement for the HTC U11 Life. However, I can’t find it anywhere.
Does anybody know where to find a battery replacement for this device?
If I can’t find a battery replacement, is there a way to start the device without the battery to recover the data?
Thanks,
Alex
Score 1
Add a comment
Chosen Solution
This is a unibody device with an internal battery that cannot be removed.
https://support.t-mobile.com/docs/DOC-36...
Score 1
4 Comments:
Is there a way to start the device without the battery when it is connected to a computer?
by
I'd plug it in to the computer let it sit for an hour and then open iTunes and see if you can sync it one last time.
by
Of course it can be removed. It isn't unibody, because when old battery swell enough, then whole plastic back just pops out.
Replacing battery is pretty straightforward, except dust/water proofing, which in case such old phone, will be nonexistent anymore.
All you need to have is some pry tool and Torx T5.
by
@dvnamic unfortunately no.
by
Add a comment
maybe you can try this one. I can see they sell on Amazon too.
Score 1
1 Comment:
This battery worked for me - X-Longer, Model CS-HTU110SL, Capacity 2500mAh, Lithium Polymer, 3.85 V DC, Part # B2Q3F100.
by
Add a comment
Add your answer
Alex will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 31
All Time: 2,565
