Up to 20% off select tools
The Canon Pixma iP3600 is a compact inkjet photo printer that weighs 12.3lbs and is 17.0”(W) x 11.7”(D) x 6.0” (H). This wired printer was released as part of Canon's Pixma series in 2008.
error canon printer 5B00
How to reset the error 5B00??
Score 12
1 Comment
شكرا لتعاونكم معنا
by Share
Add a comment
Chosen Solution
I had the same issue and fixed it this way.
Step 1: Download WIC Reset Tool here: https://resetkey.net/download and install program.
Step 2: Connect printer to computer, connect computer to internet.
Step 3: Get the reset key : https://resetkey.net
Step 4: To reset Canon 5B00 Waste Ink Counter - 5B00 Error – You should be PUT CANON PRINTER IN SERVICE MODE!
Step 5: Click on Clear Waste Counters then enter the reset key to reset your Canon printer 5B00 error
Read more here: https://resetkey.net/how-to-reset-canon-...
Score 4
Add a comment
Press and hold the power button (While connected to power)
Press the 'cancel' button SIX (6) TIMES.
Release all buttons.
Press 'cancel' button FIVE (5) Times.
Press the POWER button ONCE.
Press the power button to turn off the printer then turn on again.
Regards,
Will
Score 1
1 Comment:
Ink needed to clean the inkjet printerheads goes to a reservoir. The purpose of the reservoir is to evaporate the inksolvent leaving, after time, a residu in the reservoir. Once the reservoir is filled with residu this procedue will not work
by Share
Add a comment
Add your answer
Florence Hu will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 68
All Time: 4,576
