Smartphone designed by Xiaomi in the Redmi Note line.
redmi 4 not turning on
redmi 4 last night battery drained fully morning connected to charger presses power button mi logo appeared stuck with same mi logo after 20min so again pressed power button continuously to turn it off , since then no beep, no led , no response tried with multiple ways connecting with laptop usb , different charger , different connecting point , even removed & connected battery pin , No luck , pls suggest almost imp data & reports from past 3days am stuck
Score 1
Add a comment
Check out this article How to fix mi logo stuck during boot process, bootloop problem solution this will help you even i have solved my issue.
Add a comment
redmi note 4 charger cable insert mobile on remove cable mobile turn off
1 Comment:
by
Add a comment
Add your answer
Balraj raj will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 12
All Time: 373
