All about the Fujifilm X20.
Refuses to turn on
For some reason my X20 will not simply turn on. I have charged the battery still nothing Help please
Score 1
Add a comment
Have you tried pressing the play button to turn it on?
1 Comment:
Hello Andrew 6, I have same problem and when I press play button it starts playing the photos but the switch is of. If I switch on it will not do anything, could it be this fuse? Thanks in advance
by
Add a comment
I’ve had exactly the same problem on my X20. I followed the disassembly guide and traced the fault to a blown fuse on the main board, a tiny SMD fuse in 0603 package. I believe this is rated at 2.5A. I’m going to replace it and if it works I will add a replacement guide. Hopefully there are no follow-up faults.
Update (05/14/2020)
I’ve replaced the fuse on the PCB and reassembled the camera - it is working absolutely fine now! I've added steps to the disassembly guide to show where the fuse is located.
1 Comment:
Where is this fuse located? Is thid fuse easily available?
by
Add a comment
Add your answer
Angus will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 34
All Time: 1,383
