Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
Earpiece Not Working After Screen Replacement
This is probably the THIRD iPhone 8 or 8+ that has had this issue. Even though we were careful to remove the camera flex cable and the tape with it, and transfer it to the new LCD/Digitizer assembly, the earpiece REFUSES to work. The camera works just fine. I need assistance and answers. I have cleaned the contacts with alcohol. I have installed Kapton tape. I have switched out the piece with a new flex cable and new ear piece speaker. Yet, I know it worked BEFORE we took the phone apart. Suggestions on how to use the ORIGINAL flex cable?
Score 9
Add a comment
1 Answer
You want to make sure that the metal bracket that covers the earpiece and speaker is properly aligned, and none of the tiny springs on the receiver are bent or improperly seated. They should all evenly be pressed when the bracket is screwed into position.
3 Comments:
Thank you for the suggestion. I had to get this back together for the customer, but a weird thing happened. I test it without the bracket for the flex cable installed on the logic board. In a last ditch effort, I cleaned the connector to the logic board and installed the bracket. Then it worked!
by
Good work, glad you figured it out, cleaning the connector was smart too, pesky iPhones haha.
by
I will try everything,,earpiece not worked then I changed the screen back to originaland violaearpice now working,, solution is : use only original LCD
by
Add a comment
Add your answer
Scott Thompson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 20
All Time: 7,581
