Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
Can someone identify this component
Hi can anyone help identify the component which should be located in this photo circled in red , it was missing and the small component next to it was off its pads looks like pry damage to me .
It is near the short connector which go's to the display.
zxw tools doesn't seem to be much help with this board ..
Board is 820--00180-B .
Score 1
2 Comments
Hey, were you able to resolve the issue? Was it a bad screen? Was it the Tristar Chip?? I’m having power issues with mine
thanks
by
@travelpro85
Hi , no this one went into the box of spare parts ..
by
Add a comment
Chosen Solution
I just checked a mini 4 board I have on the bench. This is a 100K / 01005 resistor acting as a pull-down. This is similar to the circuitry on the iPad mini 2 (see R2241 on page 19 of the schematic).
Score 3
2 Comments:
Thats great , thank you , do you also have the correct orientation of the 1610A3 chip , it looks like this has also been replaced , i want to check it is on correctly .
As when i connected the charging cable i had the apple logo briefly then connect to itunes but back to black screen as soon as cable is removed .
it will not connect to itunes on pc either , so im thinking maybe the tristar chip not fitted properly judging by the pry damage .
by
If you look at the logic board length wise, with the WiFi Ic to the right, then the dot on Tristar is at the top-right hand corner.
by
Add a comment
thanks for your help , just to be certain , this is correct ? .
3 Comments:
Yes, that's good.
by
Hi again , ive replaced the chip , still no joy , could you please check your board to see if there should be a component on the pads to the left of the cap just above the chip in the photo ,
From the limited zxw board view it seems there should be .
by
Very strange symptom when plugged in see video , https://www.youtube.com/watch?v=7lG82F3j...
could this be because the screen is smashed ? . The battery is dead flat too.
by
Add a comment
Add your answer
markparnell1972 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 1,368
