The second generation model's body has a wider track and longer wheelbase than the previous MDX. The engine was upgraded to a 3.7 liter V6 tuned for 300 hp. It accelerates from 0-60 mph in 6.5 seconds, one of the most powerful engines Honda has produced to date.
How to replace sunroof switch from overhead console
I need to replace the sunroof switch on my 2011 MDX from the above console but I’m not sure how to take it apart after removing the 2 main screws. I can’t seem to see what holds it back.
Any help would be appreciated.
Thanks
Add a comment
1 Answer
Most Helpful Answer
I was able to successfully replace the switch. The is 2 Philip screws in the sunglasses holder and two clips towards the sunroof. You just need to pull downward slowly and the two red clips will give. It was a faulty switch
Problem is resolved.
Hope this helps someone else. Good luck with your project .
Score 1
Add a comment
Add your answer
x1 LbL Onetime will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 44
All Time: 1,695
