The LG 37LF65 LCD television, was released in 2007 and available in sizes: 32'' 37'' 42''.
Is There a Secret to Using a 2.1 System?
I have connected my computer to my TV using an HDMI cable, so I do get sound from the TV when I use an Youtube video. The problem is that I have the 2.1 system connected to the jack in the rear of the TV - and it is picking up no sound at all.
Add a comment
1 Answer
Most Helpful Answer
I looked at the on line docs for your LG 37LF65 tv and the only audio out I see is an optical output. Does your 2.1 audio system have an optical input? If so then that is how it needs to be hooked up to the tv audio output channel.
Score 1
1 Comment:
Hi,
To add to the answer, you also need to set the TV speaker setting to OFF when connecting an external audio system.
Go to Menu > Audio > TV Speaker > Off then EXIT to return to the normal viewing screen.
by
Add a comment
Add your answer
Richard Messina will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 264
