Repair guides, disassembly, and troubleshooting information for the 6th-generation Apple iPad with Wi-Fi, available with 32 or 128 GB of storage. Released in March 2018. Identified by model number A1893. Features a 9.7" Retina display and 64-bit A10 Fusion chip.
Can you replace the home button and still retain functionality?
Just looking to retain home button function, I am not concerned about retaining Touch ID.
If it can't this is going to push along of schools into paying for apple care.
Score 4
Add a comment
Chosen Solution
Replacing the Home Button will not retain the TouchID functions but it will allow you to "push to click". If you want to change the HB yourself, check out this guide.
Score 5
2 Comments:
That guide only tells you how to remove. I have found no documentation concerning home button function after replacment.
Just wanting to see if Apple pulled the same trick with the home button that they did with the iPhone 7 and 8.
by
It's a physical actuator, just like all the iPhones before the iPhone 7. You can see it in the picture above (that little black dot in the middle of the button). So if you change the button, you maintain "push-to-click". The iPhone 7 has a solid state button which is why replacing it kills all functionality.
by
Add a comment
Nathan,
On the iPad 6 if you replace the home button it will continue to work as a home button without Touch ID. The issue regarding the iPhone 7/8 was due to it being a solid state button, while the iPad 6 button actually physically moves.
I hope this helps,
Charlie B.
Source: 2 Years experience
Score 2
1 Comment:
Do you mean after screen replacement with original home button still Touch ID will not work ?
by
Add a comment
Add a comment
Add your answer
Nathan Selby will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 34
All Time: 4,809
