Up to 20% off select tools
The Bose SoundDock XT is a device used to play music and charge mobile devices.
replace of iPhone conector
Hi , I have this bose dock but the iPhone conector broke, it is really easy to take off but I can't find a piece to replace. Can you help?
Add a comment
1 Answer
If the 30 pin iPod connector is detached from the dock you might be able to salvage it using an Apple 30 pin to USB cable. You would need to solder the wires from the Apple cable to the corresponding connections inside the dock. These docks are available used and NOS on Ebay if you are not comfortable soldering 30g wires.
Add a comment
Add your answer
alinecass3 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 16
All Time: 837
