Up to 20% off select tools
The HP Officejet Pro 6835 is an ink printer that has a built in scanner and copier. Pages can be printed directly via USB connection or over WiFi. The printer can be identified by its model number: J2D37A
Help bypass Code Ox6100004a
I have a code on my printer that reads paper jam or repair/replace ink. I replaced all ink, checked all paper access points. No jam and full of ink. Code still remains. Any info would be much appreciated.
Add a comment
1 Answer
Perhaps the following post will help:
"There is a problem with the printer or ink system"
Seems to be exactly the same problem you are seeing. Be sure to read all of the comments/replies.
Add a comment
Add your answer
butlercanecorso will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 1,158
