A standard cordless compact DeWalt 18V drill with a high performance motor that delivers 380 watts. Equipped with easy to hold design that allows you to work in difficult spaces.
Why is my trigger stuck in forward or reverse
Trigger is stuck on unless the battery is removed or the directional selector is between gears. How do i fix it or where can i buy the parts.
1 Comment
It is a dewalt dw929
by
Add a comment
1 Answer
Chosen Solution
Planemech -
I occasionally have that issue with one of my drills. I spray WD40 into and around the trigger and work it back and forth vigorously. Let the excess drain out. Usually that works. Electrical contacts are well above trigger housing area, so no problem there.
Good luck,
Russ
Add a comment
Add your answer
planemech_2 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 36
All Time: 4,270
