Up to 20% off select tools
The Canon EOS 40D is a 10.1 MP digital single-lens reflex camera released in August of 2007.
Some pictures from camera
I created some great pictures on my camera. I tried to post-process it in Adobe Illustrator. But today I at opening one of my pictures in Illustrator I saw Can’t open the illustration. The illustration contains an incomplete or garbled object description. After this message I suppose I have to repair illustrator file. But I've no idea how and how fast I might do it.
Add a comment
1 Answer
Place the damaged Illustrator file in a new Illustrator file.
In case the method in the following can’t help, one of ways below might assist
https://helpx.adobe.com/illustrator/how-...
https://download.cnet.com/Recuva/3000-22...
https://onlinefilerepair.com/en/illustra...
Important: This solution doesn't work if you didn't select Create Compatible PDF File in the Illustrator Native Format Options dialog box when you saved the original file. On the Macintosh platform, the damaged Illustrator file may appear dimmed in the Place dialog box, but you will still be able to select it and place it in the new Illustrator file.
1. In Illustrator, choose File > New.
2. Select the appropriate size and color mode, and then click OK.
3. Choose File > Place.
4. In the Place dialog box, choose All Formats from the Files of Type pop-up menu (Windows) or choose All Documents from the Show pop-up menu (Mac OS), choose the damaged file, and then click Place.
5. Name and save the file.
Add a comment
Add your answer
Louise Pearce will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 3,160
