Repair guides and support for a wide range of Vespa scooters.
2015 Vespa Primavera 150
My wife rides a 2015 Vespa Primavera 150. Over the winter the battery went dead and will not hold a charge. Is there a battery upgrade from the standard acid battery? Like lithium ion or any other that you can think of?
Score 2
Add a comment
Most Helpful Answer
@americancj7 no because the charging circuitry would have to be different. In your case for now I'd replace the battery with a new one. It is most likely shorted out and thus does not hold a charge. If you are really handy you could most certainly build one out of capacitors but this will depend on your abilities and potentials to getting the right parts.
Score 1
Add a comment
If replacing the battery dosen’t solve your problem then you could have a problem with the voltage regulator if your battery dosen’t hold charge. Try to see if that is not faulty and replace it.
Add a comment
Add your answer
Tyler will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 65
All Time: 1,048
