Sony Xperia Z3 Dual also known as Sony Xperia Z3 D6633 is announced in September, 2014. It features 146 x 72 x 7.3 mm (5.75 x 2.83 x 0.29 in) body, IP68 certified, 5.2 inch display and 20.7Mp rear camera.
Loudspeaker Antenna low volume
Hello,
I had a problem with Xperia D6633 loudspeaker. So I disassembled the phone and tested the speaker.
The speaker sound and level is fine, but as soon as I place the small plastic antenna part (the one that clips over the loudspeaker) the sound becomes very low.
Has anyone experienced that problem, and if so how did you solve it?
Thanks
1 Comment
Thank you for the reply.
The phone is already opened. And yes I checked the grill and cleaned it with a brush with alcohol. There something pressing on the speaker and muting the sound when fully assembled, but I can't find which part is pressing on the speaker.
by
Add a comment
1 Answer
Most Helpful Answer
Have you checked the speaker filters? I'm not exactly sure where they are located but I would assume at the bottom of the screen as you can see the grill from there. I would try 99% isopropyl alcohol brushing on the bottom filter without opening the phone up.
Score 1
Add a comment
Add your answer
Ahmed Wahdan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 16
All Time: 593
