Electromechanical calculator which graced many an accountant's desk between the 1920s and 1960s. The underside of the machine has a slot which, if you peer into it with a flashlight, will reveal the stamped designation LA-160-(serial number).
Reccomendations for restoring and cleaning?
I've recently acquired an LA-160 and I will be using your guide to dissassemble it and make sure the innards work correctly. I was wondering, however, if you have any advice on cleaning the insides or anything?
Add a comment
1 Answer
Dug around to double check my work and found this. http://www.vintagecalculators.com/html/m...
Contained within are a operating manual and a more detailed service manual that contain adjustment and lube
Add a comment
Add your answer
Brandon Mather will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 26
All Time: 416
