A splash-proof, portable Bluetooth speaker from JBL, released September 2015.
Why wont it charge
My speaker wont charge with the manufacture charger nor with others I have tried. I've had this speaker for less then two years and baffled.. need help
Add a comment
Most Helpful Answer
When your Bluetooth speaker does not charge up its battery, then it is not necessarily a bad battery or speaker. It could also be that the USB cable or the charger itself are broken. ... It usually was just sitting in the drawer, waiting to be used for charging my JBL Charge speaker
Score 1
1 Comment:
Yeah I’ve used different usb cables and no luck.
by
Add a comment
@socalcv07
if it won’t charge while you use a proper charger and cable, start by replacing the battery. Something like this video will help you with that. After that re-evaluate and if it still does not charge, the battery/charger port could be faulty.
Score 1
Add a comment
Add your answer
Socalcv07 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 25
All Time: 2,422
