Up to 20% off select tools
The next-generation 2007 Santa Fe debuted at the 2006 North American International Auto Show in Detroit.
How to replace radiator
how fixed water tank
Score 2
5 Comments
what year is the santa fe
by Share
A 2012 Hyundai Santa Fe, have radiator leak, replaced top hose already, still leaking. Can't find a Youtube video for 2012 Santa Fe.
by Share
Just to know how to repaired
by Share
How to fix or replace radiator
by Share
@Martin Caine
What is the year model of the vehicle?
What's wrong with the radiator?
by Share
Add a comment
Most Helpful Answer
Here's a video on how to do it:
https://www.youtube.com/watch?v=apAy-nfb...
Score 1
1 Comment:
While this video is pretty decent, it's for the 2006 model which has some significant differences. I'll have to verify on a 2009, but IIRC the top core support on the 2007 and later doesn't just pop off with 4 screws as shown here.
by Share
Add a comment
@lilirishpol ,
Did you check for any coolant stains around the base or seams of the radiator or around the radiator neck etc?
If around the base of the radiator you may have a leaking radiator core or if on the neck of the radiator, a faulty radiator cap.
Get the cooling system pressure tested to see if the leaks show up.
Score 1
Add a comment
Add your answer
daniel paintsil will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 48
All Time: 11,671
