A general-purpose audio device that transmits low audio frequencies to your ears.
How to wire subwoofers
New at the car audio I have 2 12 inch svc 4ohm subs and 2 dvc 6.5 4ohm subs what's the best way to hook them up and what kind of amp should I use
Add a comment
1 Answer
Chosen Solution
Please have a look at this instructable https://www.instructables.com/id/Install...
Score 1
3 Comments:
Know a little I never got into the channel amps and I'm sure I need more then one I'm thinking about another amp I have I mono amp now for the 12s
by
As long you amplifier can handle 8 ohms - you should be more than fine with both subwoofers on one amp. Using 2 different amps you could have muck ups with sinc witch could cause delays on other sub.
by
Well the I have now is a boss 1100 riot mono so I have to get a 2 channel amp ?
by
Add a comment
Add your answer
jeffbennett789 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 343
