Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
Very difficult to move in reverse gear.
The truck will shift through all forward gears just fine without any trouble, but when I put it into reverse I have to give it probably around 3000 rpm to move at all. Trans needs serviced bad. Just wondering if that's my issue or if I have something more to worry about. 1992 Chevy c1500 5.7L automatic 4x2.
2 Comments:
Once in a while I can get lucky and get it in reverse but I can't count on it
by
If I can get it in reverse it will not move and occasionally it's almost like it's stuck in gear
by
Add a comment
1 Answer
If your trans needs a service bad, it might be failing. I'm not sure how many miles you have and how you maintain the car, but by the sound of it, it might be slipping in reverse, so you would need to get a new trans, or get your old one rebuilt. Both are expensive unless you can find one in a junkyard for a good price.
1 Comment:
It is probably the transmission/torque converter. I had the same problem with a prior car...it would lose power in reverse. Quickly shifting into neutral and back to reverse made it work momentarily.
by
Add a comment
Add your answer
Cole Custer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 1,323
