The Alcatel One Touch Idol 3 features a 5.5-inch, 1080 x 1920 display powered by a 1.5 GHz processor. Released in June 2015. Models 6045Y, 6045K, 6045O, 6045I.
Why does phone gong instead of ring?
I have an Alcatel One Touch Idol 3. Occasionally, instead of ringing like it should (using the ringtone I selected as default) the phone just gongs slowly. It particularly happens when my son calls (I have no idea why). The problem is that the gonging sound is quite low in volume, and I almost always hear it too late to answer in time. Does anyone else have this problem, and if so, how can I fix it?
1 Comment:
Hi Joe,
Has the gonging ever happened when someone other than your son called?
by
Add a comment
If the ring tone only makes that sound when your son calls and with no one else , then it sounds like you or your son set the ring tone to that sound. You can set different ring tones to each individual contact. All you have to do is go to your son's contact, click edit, scroll down to were it shows ringtone, and then change it or set it back to default.
Add a comment
I already checked that. The ringtone was set to default.
Add a comment
Add your answer
Joe Perrone will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 325
