How do I reset the change oil light?
Turn your key to the "On" position, but do not start your vehicle.
At this point some Chevy's differ:
(Try this way first) Pump your gas pedal 3 times within 5 seconds
or
Use the button on the dashboard that has an "i" on it or has a road on it. Pushing this button should cycle through mileage, tire pressure..etc. You want "Oil Life", then push and hold the check-mark button until the oil life resets.
It has been awhile since I worked at Jiffy Lube, but this is how I learned to reset the change oil light on Chevy's.
Also, you can check your Owner's Manual and it should tell you how.
Mine 2007 Chevy Suburban LS I did the first one, pushing the brake and holding within 5 seconds didn't work. The second one worked using the "i" button going to oil cycle and holding until my oil life resets to 100% great for google/computers and technology.
Also thanks Matt your Info was helpful......
First step with gas pedal worked for my 2006 equinox thanks man
For my 2005 model, turn the key to ON without starting the vehicle; push the accelerator all of the way down three times within 5 seconds. The light will flash as it resets, turn the ignition to the OFF position.
Mine is to push the brake pedal all the way down 3 times within 5 seconds and the oil light will flash and then stay off. Do this while the key is in the "On" position.
This worked for my 2006 equinox thanks man
This it is the full procedure how to reset oil service light Chevrolet Equinox. If you like to reset any maintenance oil light after an oil change. Or reset check engine light, airbag light, inspection key or insp errors when maint reqd, for Chevrolet cars. Or any warning light for service reminder which appears on the display.
http://resetservicelight.com/reset-oil-s...
This is an information site where you can solve your car problems.
I lost the key will it start without it
Past 24 Hours: 1
Past 7 Days: 46
Past 30 Days: 156
All Time: 159,298
3 Comments
how do I reset the oil light for a 2000 Daewoo nibura wagon?
by jill
I have a 2007 Chevy Tahoe I try every procedure there is to set my oil life back to 100% I change oil in my oil life is still at 0% I hit the I button to my oil life came up to zero percent and I hold the check button to change oil light to a hundred percent in this method does not work for me or your life is still at 0% what do I do to set my oil life back to 100% what may be wrong with my vehicle could I try every procedure that I could
by joewsr.56
I have an 2007 Chevy Tahoe and my oil still is at 0% nothing works what do I need two dozen?
by aflipette
