Second generation phone released in November 2012. Available in stealth black or polar white / 32 or 64 GB / micro sim card / no sd card slot. Model #PM63100
battery discharge very fast
When i charge my phone and complete charging then when i started to use my phone
it is immediately shut down
Score 1
1 Comment
Hi mfshahri, could you solve your problem?
by
Add a comment
1 Answer
Most Helpful Answer
@maxnet ….either one of two thing is happening. your phone goes into a charging state but is not actually supplying voltage to your battery or your battery has dead cells and is not actually taking a charge. you can test which one it is by verifying the voltage is travelling from your charging port to your battery terminal. if the voltage is there, change your battery. if not, start troubleshooting your charging port circuit. here is some basic troubleshooting guides for your phone:
HTC One X+ Troubleshooting
you can also test your battery to see if its short or taking a charge by reading its internal voltage at different intervals while charging.
Technique - Test the Battery
hope this helps. post back here for any further assistance
Score 1
2 Comments:
Thank you very much. For me it was the battery. As I swapped it, it works again.
by
good to hear. good job.
by
Add a comment
Add your answer
mfshahri will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 285
