The Verizon Ellipsis 8 is a tablet that features an HD display, 5000 mAh battery, and 4G LTE capabilities.
keeps rebooting ,optimizing app 135
Add a comment
1 Answer
Most Helpful Answer
Hi,
It may be that a downloaded app is causing the problem.
Try starting the tablet in safe mode to check that it starts up OK without rebooting.
If it does then a downloaded app is the problem. The trick is to find out which one.
If you have just recently installed or updated some downloaded apps and then the problem started try uninstalling them first, one by one. Check between each uninstall if the problem has gone by trying to start the tablet in the normal way and see if the problem has gone. If it has then the last app uninstalled was the problem
Score 2
Add a comment
Add your answer
gus pappas will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 13
All Time: 996
