Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
Logic board schematics and testing procedures needed
I've inherited a "fried" imac from a friend. The machine was reportedly hit by a power surge from lightning although a surge protector was used. The machine will not power on, no boot chime, etc. I have reset SMC and the fans kick on in high speed but machine will not boot. I took apart the machine and inspected the logic board for burns, etc. and could find nothing. Replaced the RAM; nothing. Power supply tests out fine and I even replaced with a new unit; no change. On the logic board, I get LED#1 when the machine is plugged in, but when switched on, no other lights ever light up. I can get the fans to come on at high speed, the hdd and cd drives sound like they're getting power. My question is; I see all of these logic board repair services out there, what are they normally fixing and where are they getting their schematics etc from? This is not my everyday computer so it's kind of a hobby project at this point. Ultimately, if I cant fix it, I will probably have a pro get it going, but I would like to give it a shot.
Score 2
10 Comments
To any of you following along, schematics are available here:
http://www.laptop-schematics.com/
Cost is approx. $30 per machine.
by
seems a shame to buy the schematics and have taken the mac apart just to give it to someone else to fix... give it a shot. we all start somewhere and mayer is a very clever/helpful man!
by
Well thank you Polly. You got me to blush
by
I'd spend some money on trying to get the valid schematic for your computer. Since you described it to be hobby, what better way than to get the Mac revived with the help of the experts on here and to follow their advise. mayer is always a great source of experience and knowledge. Good Luck.
by
ABCellars, why would you vote to remove this as spam/offensive? Am I missing something?
by
Show 5 more comments
Add a comment
Most Helpful Answer
Check the LEDs after changing the power supply and let us know.
Score 2
1 Comment:
In the initial description it was stated the power supply had been changed,
by
Add a comment
Did you examine the capacitors on the logic board to make sure none of them are busted? Look for swollen or bent caps. Thats about all the advice I can add
Score 1
1 Comment:
This is not one of the G5 iMacs that had the bad caps problem, but it couldn't hurt to look.
by
Add a comment
Add your answer
info251 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 9
All Time: 5,488
