The Panasonic Lumix DMC-FH20 is a 14.1 megapixel digital camera. It is available in black, silver, red, violet, and blue and is a point-and-shoot camera.
camera does not recognize external sim card
Hello,
Wondering if there is a repair for this camera that is not recognizing the external sim card.?
Add a comment
Most Helpful Answer
Hi, same problem in 2023! (I gave this camera for my 3y old daughter). My solution was change the format FAT32 to NTFS. I have inserted the SD card again then the camera recognized and asked my to format and voila, it worked!
Score 2
Add a comment
Do you mean an SD card? You may need to make sure the card is set for use with cameras, you can fiddle with it in the menu options and card options that your computer allows you to have, then you can set it for camera. Then if you get it in the camera, go to format and it can specify it with the type of camera details and processes.
Update (05/12/25)
Yeah, on the computer right click on the card in the menu. Then go to settings, and program from the information offered. If a person goes into these options backing out will not change anything, so the options can be explored.
Score 1
2 Comments:
I have an memory card and new battery in camera, but does not work. I am very green about technology so don't talk in camera lingo
by
There are manuals to get camera use guidance, often as free downloads. The TS4 menu options are between the arrows on the lower right, in addition to the lower left menu button.
by
Add a comment
Add your answer
Robert will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 30
All Time: 661
