Up to 20% off select tools
Guides and repair information for vehicles made by SEAT.
How to replace airbag sensor?
My Seat Mii airbag light stays on due to faulty sensor readings, how to replace the airbag sensor?
Score 2
1 Comment
Go to your dealer and ask if your car is part of the Tecata airbag recall. Also ask if it has any recalls or TSB's relating to the airbag senors. Audi does and it involves cutting and joining wires.
by Share
Add a comment
1 Answer
Chosen Solution
I would suggest that anything to do with airbags should be consigned to a professional - your life could depend on it! And if you do something wrong you could accidentally fire the airbag.
Score 4
1 Comment:
Anyway even if you fix a source of the problem you must clear fault code, otherwise fault light will not go out
by Share
Add a comment
Add your answer
Thorstin Crijns will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 33
All Time: 1,856
