The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
Idles to low after repairs
I recently made repairs to my 91 Camry 4 cyl including replacement of plugs, wires, distributor cap and rotor. It ran awesome for a couple hrs but is now idling to low and stops if I do not have the gas slightly pushed. How can I set the idle higher?
1 Comment
Did you by chance, twist the distributor ? The slightest tweek in spark timing would cause idle-speed to change.
Also check for a vacuum tubing not connected.
That being all OK, Remove the plastic air-intake to where you can see the throttle mechanism move when your helper steps on the gas. That thing has a easy-to-find-stop-screw for setting idle-speed. Turn it clockwise to idle faster. Stand to the side, have helper hold the brakes, put it in drive, and see how it idles.
Thats it - clean all the air intake parts while you have them off.
I had the big 6cyl toyota.
It had six pieces of plastic plumbing under the hood !
by
Add a comment
1 Answer
Chosen Solution
Just letting all know that I fixed this problem then moved on to yet another. Thanks for the help!!!
4 Comments:
What did you do to fix the problem, please post so others can share.
by
After replacing the plugs and wires, distributor cap and rotor I found that the car was idling so low I had to keep my feet on gas and brake to keep it from dying. I realized the air intake hose at the carb. was not staying tight and that the hose was actually cracked. I went to Auto Zone and bought a coupling/clamp combo, thus idle was almost perfect. I paid like $9.00 for the part and worked like a champ!!!
by
What the hell; s a coupling/ clamp n g e what?????
by
@kenzforbes Probably something with a piece of hose and a pair of clamps; something like this.
https://www.autozone.com/intake-system/a...
by
Add a comment
Add your answer
ALANA will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 23
All Time: 637
