The Moto G4 Plus is an improvement on Motorola's Moto G4. The Moto G4 Plus offers a fingerprint sensor, increased memory capacity, and an improved rear camera. Model number XT1642 and XT1644.
Device not charging. tried replacement
hey guys. i do charging port replacements on a regular basis. i have soldered on all models of phones dating back to the BB9900, so i can tell you after 3 ports, that it is not the port failing.
I have also ordered and replaced the battery resulting in the same failure.
i have scoured the board under a 10X microscope, and find no physical damage to board, or related components
The device says its charging, however, the % does not go up within an hour.
1 Comment:
i have the same issue
by
Add a comment
1 Answer
It could be that the device just cannnot detect any battery that is it is given. I'd suggest checking the connection when you connect any battery.
Add a comment
Add your answer
Scott will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 12
All Time: 698
