The Brother MFC-440CN is an all-in-one color inkjet printer with a photo bypass tray first introduced in 2001.
Clear "paper jam" message
On a MFC-4420DW I'm attempting to print business cards on Avery stock through the rear, single sheet feed tray. Data transfer from PC is very slow, and when printing begins only the first quarter of image prints and sheet exits printer. Thereafter I get a Paper Jam message. I have followed the "clear paper jam" instructions several times, referred to online instructions, used a letter-sized sheet of glossy photo paper for the "remove paper scraps" function, but printer does not grab the sheet. I have closely searched the inside of the printer for scraps and can't find a thing. How can I clear the error message so I can use my printer again?! Frustrated!
Add a comment
1 Answer
Most Helpful Answer
Hi,
Have you set the printer preference Media Type in the computer, to 'other photo paper' to allow for the thicker paper that you are using? You didn't say.
if this doesn't work in the Paper Size preference you can specify the 'thickness' of the paper that you are using.
What OS is installed in the computer connected to the printer?
Score 2
Add a comment
Add your answer
katiepricega will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 770
